Picked up my '04 disco se!
Old Jul 17, 2012 | 09:02 AM
Originally Posted by andrew12159
Discomike, do you think the toyota corolla condenser fan motor is strong enough? It's 70 bucks is new and looks like a perfect fit.
It is not the size but the flow volumn that you need to match and or better.
Old Jul 17, 2012 | 09:03 AM
Next on your list should be the front drive shaft, listed on my major service list, if it fails you, it could cost upwards of $3000.
Old Jul 17, 2012 | 10:22 AM
drowssap's Avatar
Mike is quite correct about the CFM, the volume of air being moved is much more important than the size or the rpm of the fan. That being said you will have trouble fitting anything larger than a 12 dia. in their so keep that in mind when looking around.
Old Jul 17, 2012 | 02:22 PM
andrew12159's Avatar
I wish I knew the cfm of the stock fan. Nobody knows it so it's hard to shop for one. I am going to do the severe duty fan clutch today and the Toyota condenser fan motor comes tomorrow. In the meantime no Ac.
Old Jul 17, 2012 | 07:06 PM
You will be fine with the Toyota fan motor, it is the exact same motor so it spins at the same speed as the Rover motor, the difference is the fan blades, which you will be swapping over.
redlyne_mr2
Apr 12, 2010 09:26 PM
sn1987
Oct 12, 2009 09:53 AM
Backpoints
Jul 7, 2009 02:42 PM
IDAHODISCO
Feb 21, 2009 10:04 PM
dombam
Oct 22, 2008 10:22 PM
