Pictures back of instrument cluster,04 Disc. II
Old May 13, 2012 | 07:12 AM
rockyblue123's Avatar
Default Pictures back of instrument cluster,04 Disc. II
I took the instrument cluster out of my 2004 DiscoII. Put it all together, Everything works, Fuel cap release etc. but now Temp Gauge and tachometer INOP. Anyone have pictures of back of cluster. I think I prob. might have put one or more of the connectors in the wrong place.
Thank you in advance.
This site ROCKS !
Old May 13, 2012 | 07:47 AM
here you go. In the RAVE, circuits diagrams, there are tiny numbers by each wire. Look up the C-number in the connectors list in the electrical library. If you had the RAVE, you already had the pix. Don't think you swapped these two, because one is 20 wires and the other is 16.
File Type: pdf
Old May 14, 2012 | 08:37 PM
OK, well I found the problem. I had the circuit board out, (again). I noticed there are 14 screws and 16 holes. Turnes out the srews holding down the circuit board actualy complete the circuit. I noticed 2 of the holes for the screws on the circuit board had no circuit behind it. So I didnt put screws in those holes. Now Tach and Temp gauge work. YEE HA! Rule I live by. If something doesnt work or doesnt make sense, go back to the beggining and go to the simplest form of the problem. Works every time. Hope this helps someone out so they dont make the same dumb mistake I did. None the less, Im a proud Mo Fo for finding the fix. Thanks Peace out !!!
riko suave
Mar 18, 2009 04:34 PM
Panic
Feb 23, 2009 01:41 PM
CandiMan
Oct 30, 2008 01:39 AM
coldfrez
Oct 1, 2007 09:49 AM
Greg
Aug 8, 2007 04:47 AM
