Pictures of an exploded Joint that destroyed transmission
The double cardan joint cancels the angular velocity variation that a single U-joint cannot, but there are multiple newer, simpler and cheaper options that they could have adopted.
Nevertheless, its is a Land Rover and what else can I say!!!
On the other hand, I have been looking at building a drive shaft with a CV joint that will do a better job than the double cardan joint and it will require no grease since a CV joint has a boot that encases the joint and keeps the grease inside.
What the heck ever happened to driveshaft hoops?
If I had a DII, I'd spend an hour and weld one up
Doesn't the carrier unbolt like my DI? - I'd put a 4-6" hoop off that, no wait, I'd probably
check it twice a year as I do with my DI, never mind. (No desrespect intended to anyone)
luck,greg
luck,greg
