Pinion seal leaking?
Old Jul 16, 2015 | 09:03 PM
mose802's Avatar
Default Pinion seal leaking?
Just noticed some drops below the rear differential. Looks as if it may be the pinion seal. Should I replace it or try some stop leak? If I replace it how hard of a job is it?
Old Jul 16, 2015 | 10:05 PM
OffroadFrance's Avatar
If you can remove the rotoflex spigot easily it should be relatively easy and you can hold and torque up the pinion nut on assembly. I reckon if you are used to spanners, have a garage it's about a 2-3 hour job.
Old Jul 17, 2015 | 06:13 AM
Replace it and when done make sure you use a 85/140 gear oil for better wear protection.
Old Jul 18, 2015 | 08:57 AM
Mike, I've changed recently to a high quality synthetic 75/90 and it's a tarmac trekker not used offroading, what do you think?
Old Jul 18, 2015 | 09:30 AM
Since you are not wheeling hard, you'll be OK, other wise you should run a heavier oil in the diffs and t/case to keep them running cooler with less wear.
Old Jul 18, 2015 | 09:04 PM
antichrist's Avatar
If you have the rotoflex here are some instructions on removing the flange spigot without the LR special tool.
https://www.scribd.com/doc/47742463/...Flange-Removal
outdoor7or24
May 21, 2012 08:34 AM
discoboy
May 12, 2011 12:36 AM
LRScott
Jun 2, 2009 08:37 PM
newdr
Mar 18, 2008 07:56 PM
garover
Feb 20, 2005 11:08 PM
