Plastic trim panel at bottom of windshield is broken,....will water get in?
Old Apr 17, 2019 | 08:53 AM
bcolins's Avatar
Default Plastic trim panel at bottom of windshield is broken,....will water get in?
The black plastic trim piece along the width of the bottom of the windshield is cracked. Can water get in through this area,....or is it all weather proof?
Brian in San Antonio
Old Apr 17, 2019 | 09:24 AM
NewToTheTwo's Avatar
I believe the only fear of water could be through the fresh air access thats normally behind the foam filter under the hood.
If that plastic is beat up really bad, thats something to consider.
Old Apr 17, 2019 | 03:48 PM
ahab's Avatar
Assuming your referring to this piece. As far as I know it in not intended to be waterproof and water that gets past it can drain out of the cavity below it however if your HVAC box isn't sealed up tight against the firewall then water can get into the cabin. This can happen without a broken cowl piece though.
Old Apr 17, 2019 | 06:46 PM
Extinct's Avatar
The air intake for the HVAC is under there, if its completely gone it is possible. I recently had to replace mine and bought the one on ebay from Malaysia. Fit very, much thicker and stronger, I would recommend it.
Old Apr 18, 2019 | 02:08 AM
Brandon318's Avatar
One of the wiper plug blanks was missing this rainy season and water would constantly find its way out of the vents and onto the dashboard. Ordered a new blank plug and no more water. So yes, that piece isn’t water sealed, but definitely stops bulk, wind-driven water.
Old Apr 18, 2019 | 02:50 AM
JUKE179r's Avatar
That windscreen cowl from Malaysia is my next big purchase for Myrtle.
Old Apr 18, 2019 | 08:17 AM
jastutte's Avatar
i just did the same and second the recommendation.
Old Apr 18, 2019 | 08:51 AM
bcolins's Avatar
Where do I find that Malaysian cover? I only saw one on ebay for$270.
Old Apr 18, 2019 | 09:08 AM
ahab's Avatar
https://www.ebay.com/itm/Land-Rover-...-/271589741098
If you need pillar covers too you may be able to save on some shipping.
Old Apr 18, 2019 | 01:50 PM
GCBurke's Avatar
Check craigslist in your area for one being parted out....I got one for $75 like this.
AJ1
Oct 23, 2019 08:25 PM
Philip Chan
Feb 18, 2019 09:09 AM
