Please help me explain this oil leak
I will check the trans cooler for leaks again, but so far I haven't seen any fluid coming from there. I regularly check from underneath with a flashlight. The red color could be coolant which would indicate a head gasket problem. I will check the oil drops for coolant (hot plate sizzle test) if I can collect enough.
rob bartleman (02-10-2024)
