Please help me explain this oil leak
Old Feb 7, 2024 | 09:42 AM
James2450's Avatar
Not to make fun but they all leak oil, I swear it oozes though the castings.
Old Feb 7, 2024 | 01:48 PM
Discorama's Avatar
I will check the trans cooler for leaks again, but so far I haven't seen any fluid coming from there. I regularly check from underneath with a flashlight. The red color could be coolant which would indicate a head gasket problem. I will check the oil drops for coolant (hot plate sizzle test) if I can collect enough.
Old Feb 7, 2024 | 03:45 PM
redrover75's Avatar
When I had a power steering leak I could not nail down, I would tape pieces of paper towel in specific locations where I thought it may leak. If it stayed dry I knew that was not the source.
Might help you, if the leak is higher up, you can eliminate downstream possibilities.
Old Feb 8, 2024 | 09:03 PM
rob bartleman's Avatar
Discorama... could you say a bit more about the "hot plate sizzle test?" What are you looking for in the "sizzle"? thanks!!
Old Feb 10, 2024 | 12:28 AM
Discorama's Avatar
Also known as crackle test:
Old Feb 10, 2024 | 01:34 AM
miron's Avatar
Just make sure to take a look at the cooler itself, not just the hoses. I'm mostly saying this b/c my oil cooler sprung a small leak in one of the ribs by the manifold and all that oil was being sucked into the engine bay and getting splattered all over the block. I thought i had a front seal leak and it took me 2 hours to figure out what was actually going on.
Brandon318
Mar 26, 2022 08:25 PM
Brandon318
Mar 26, 2022 08:21 PM
merebel
Aug 3, 2020 01:13 PM
satxpipe
Oct 17, 2017 08:09 PM
kpxus
Jun 17, 2005 03:58 PM
