Please help me locate a wire that determines Vehicle speed
Hi again, I need your help once again. I am trying to finish the installation of my navigation system and it requires me to tap into a VSS wire, or I guess any wire that reads the speed of the vehicle. Please help as I have my truck in pieces as we speak. Thanks SO much.
Open the interior quick release panel where the fusebox is, In there you will find a large GREEN connector with a "built in" lever to remove it. In that loom / plug there is a PINK and GREEN wire that you need to splice into. That is the correct VSS to use.
