Please help...tranny fluid.
Old Feb 14, 2009 | 09:47 AM
sharp's Avatar
Default Please help...tranny fluid.
i used castrol atf domestic dexron 111. Is this the right stuff. It says dexron 111.
I know this isn't that hard to do, but I seem to be having a problem. Last week I changed the tranny filter. Because my fluid was so dirty I was doing an additional 2 changes.
This morning I drained the trany fluid let sit for about 30 min. So the pan was drained.
I pumped, I believe 3 quarts back into he engine when it started to leak ut the filer hole.
This is where it gets interesting. The out pouring was gooey, Could this have been because it was cold out or because of any air that may have been put in from the pump.
I then started the truck, put through gears P and R 3 times. Went under the truck added another 1 quart. Again the flow out of the filler seemed cgooey. Not the smooth bead I had last week.
all in all only 4 quarts of atf went back in. I read through the forum there should be 6. And why would it be gooey. Please help so I could get her n the road
Old Feb 14, 2009 | 11:16 AM
I am concerned that it was gooey.
If it wasn't like what came out of the bottle, red, clear, then there is a problem.
PM me your tele number and I'll call you.
Old Feb 14, 2009 | 01:52 PM
llPANCHOll's Avatar
Could you keep the rest of us informed on what the resooution of this is... I am intrigued
Old Feb 14, 2009 | 07:17 PM
sharp's Avatar
Will be changing the fluid again tomorrow. I'll keep you informed of the results.
Old Feb 15, 2009 | 05:57 PM
llPANCHOll's Avatar
Update???
Why was the fluid "Gooey"
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
suntattoo80
Dec 19, 2008 01:21 PM
freeland02
Freelander
Sep 27, 2007 10:15 PM
LiftedRover96
Feb 11, 2006 01:46 PM
