PO307 code after induction/TB cleaning, no prior issues
Old Jan 4, 2010 | 11:32 AM
tornado_735's Avatar
Originally Posted by Spike555
If you have a lot of carbon build up then doing a induction/throttle body cleaning will dislodge a lot of it and it can foul the plugs and set off misfire codes.
But plugs are cheap so not a big deal if you ask me.
X2
When you clean the throttle body and intake, you are introducing stuff into the combustion chamber that is not normally present, and that is what fouls the plugs. Also, like Spike said, there is carbon and all kinds of crap that if coming loose and can also stick to and cause the plugs to not want to fire.
You already changed the plugs. Good. Change the wires too. Search around, there is a thread detailing how you can change the plug wires the easy way.
Good luck.
caleb
Dec 22, 2009 12:19 PM
meltdowndave
Nov 26, 2009 08:03 PM
mellyagaunce
Oct 8, 2008 07:55 AM
armyproud
Apr 25, 2008 07:44 AM
Scanner
Mar 24, 2008 02:10 PM
