Poly Flex front end bushings
Old May 22, 2018 | 02:16 PM
TaylorCadence's Avatar
Originally Posted by Sixpack577
Rubber go in easier, but can also be a struggle.
Silicone spray and a big C clamp can usually get it done, but, sometimes you must have a press.
I'm just talking about control arms too, as sway bar and end link bushings are usually not a problem.
thanks for the input, looks like a gotta do some more research...
Old May 22, 2018 | 03:26 PM
Sixpack577's Avatar
Yes sir, good luck with it.
Old May 22, 2018 | 08:08 PM
RoverMasterTech's Avatar
I know a guy who did all polyflex in a disco 1. Was really hard to press/massage in. had to grind down most of the bushes to fit in the radius arms and drag links. He says was worth it.
Old May 22, 2018 | 09:53 PM
its a tough call because they last so much longer. My watts link is out too and considering swapping for polys. Idk. What would be a substitute if not polys?
Old May 22, 2018 | 10:07 PM
Jeff Blake's Avatar
A press is pretty much required for radius arm bushings... OEM or poly. There are some 2-piece poly bushings that don't need a press, but you have to watch out for the chassis end, as a lot of the brands require a press on that one. (not a fan of 2-piece poly).
I fitted Terrafirma poly bushings a couple weeks ago, to replace the britpart 2 piece poly's. So far so good. OEM bushings won't fit the castor corrected TF arms anyway, so it's gonna be poly, or poly (for me).
If you don't have a press, you can probably pay a local mechanic like 80 bucks to install them. Or, get a 20 ton harbor freight press for around $140 like I did. It sits next to the fridge in my kitchen
Old May 23, 2018 | 02:44 PM
Haha im thinking I’m gonna get a press too. Taking bushings to a shop just for two diff occassions will rack up a bill that merits the purchase. And I’m thinking I’m in for a lot of bushing replacments, they’re looking pretty squashed down there! I’ll look into TF
TOM R
Dec 5, 2015 11:24 PM
TOM R
Nov 7, 2015 01:04 PM
Rover Newbie
Jul 17, 2014 07:47 AM
MarkSF
Mar 17, 2014 12:38 AM
Spike555
Jun 2, 2009 11:19 PM
