popping noise in front end
Old Dec 14, 2012 | 08:06 PM
jhill15's Avatar
Default popping noise in front end
Today I noticed when im driving under 15mph and i hit the smallest of cracks in the road i can hear and feel a popping in the front of my truck. It seems like its coming from the drivers side, and when I start to accelerate it starts to go away...or I just can't hear it anymore. Im not sure if it would be a ball joint, Ty rod...I can't figure it out. Idk? Has anyone had the same issue with their truck?
Old Dec 15, 2012 | 07:04 AM
Have you crawled under the truck and checked anything yet? We can't help without you getting involved, there are a ton of parts that can cause this problem.
Old Dec 15, 2012 | 07:25 AM
Including just a loose lug nut.
Old Dec 15, 2012 | 08:05 AM
jhill15's Avatar
Your right, I will get under there and see if anything is loose and post later today
Old Dec 15, 2012 | 11:14 AM
Make sure you check all bushings, shocks, tie rod ends and ball joints.
Old Dec 15, 2012 | 11:15 AM
You may need to jack it up and suport the frame so that the wheel hangs (no pressure on it) and shake that top/bottom in - out, movement indicates wheel bearings. With load on the the system, parts may not make themselves known as easily.
ruffram
Jan 15, 2015 01:08 PM
rayxlee
Sep 15, 2014 07:52 AM
Aaron Wasson
May 16, 2013 06:35 PM
CUpgt
Apr 14, 2010 10:48 AM
