Possible Heater Matrix Leak
Old Feb 13, 2017 | 04:08 PM
jobooth's Avatar
Default Possible Heater Matrix Leak
2004 Disco II (Bosch)
I've got a coolant leak dripping straight down on the passenger catalytic converter. The passenger footwell is dry. I've searched high and low in the engine bay and have found no leaks.
Is it possible that one of the o-rings to the heater matrix is leaking but not into the footwell? Is there a drain there somewhere?
I'm avoiding doing the heater matrix. I've heard what a pain in the a$$ it is. I figure if I'm going in, I might as well put a new heater matrix in there with new o-rings.
Thoughts?
Old Feb 13, 2017 | 04:34 PM
mollusc's Avatar
I believe that's where the sunroof drains come out.
Old Feb 13, 2017 | 05:52 PM
jobooth's Avatar
I thought it was the sunroof drain at first as well but it's definitely coolant.
Heat works. Doesn't smell in the cabin. Footwells are dry.
But it's pissing coolant on the passenger cat.
Weird, eh?
Old Feb 13, 2017 | 07:54 PM
PalmettoDisco's Avatar
Weird, eh?
It might be a leak from the valley gasket, under the intake manifold, draining off the rear of the block. Might even be at the coolant pipe exit on front of engine block and getting onto the valley gasket and draining back.
Old Feb 13, 2017 | 08:07 PM
jobooth's Avatar
Oh good gawd I hope not. But I'll look. Thanks for the idea. I didn't think of that.
Old Feb 14, 2017 | 10:48 AM
jobooth's Avatar
Ha! Found it. It's just one of the hoses leading to/from the heater core. It's dripping down right before heading into the firewall. Easy fix for once.
Old Oct 14, 2024 | 11:44 PM
03LRD2NM's Avatar
Default Hose to/from heater core
Hi. It appears I have the same problem. Leak to/from heater core.
What was the fix performed? Replacing hoses, clamps, etc?
ls1morethanyou
Jan 12, 2017 10:21 AM
lotek10101
LR2
Jan 26, 2016 02:26 PM
georgep
Oct 4, 2015 02:34 PM
russburcham
Jul 26, 2013 06:34 AM
nojeep
Jun 4, 2009 02:52 AM
