Possible short on passenger side headlamp
Old Aug 24, 2017 | 09:39 AM
brolome's Avatar
Default Possible short on passenger side headlamp
In the two years I've owned my D2 my passenger side headlight has blown multiple bulbs. I purchased Sylvanias from AAP which had a warranty, so I got a few replacements for free. Overlooked the problem because of this. Driver's side has been fine the whole time.
Most recently the bulb has blown again and now the headlight won't work at all, even with brand new bulbs (bought another 2-pack, tried both). The signals, running lights, and high beams work on both sides. The low beam works on the driver's side. I'm thinking there is a short in the wiring for the passenger side low beam.
I should note that there is a correlation between this happening and doing actual off-roading so things like water crossings, rough roads, the use of CDL, HDC, and 4lo manual shifting are other variables in the equation though I'm not saying they're related.
Has anyone had this or a similar issue? I have some electrical resources at work to investigate further but I'm just wondering where to start.
Thanks!
Old Aug 24, 2017 | 10:57 AM
LR03NJ's Avatar
Thanks!
check underneath the battery the harness run through there and wires can get kinked and get rubbed between.
Old Aug 28, 2017 | 09:18 AM
brolome's Avatar
I think this is the case. My electric-savvy coworker was able to narrow it down to the wiring harness itself. It's good until the under hood fuse box and the headlamp itself has continuity. Something funky with the wires themselves.
Thanks for your input!
cosmiccharlie
Aug 12, 2020 01:42 PM
GROVERtheROVER
Aug 29, 2011 09:37 PM
Young
Jul 22, 2009 07:51 PM
chakadog
Dec 27, 2008 05:20 PM
