potential 02 disco 2 overheats
Old Aug 12, 2015 | 04:49 PM
  #21
Dave03S's Avatar
How long has the previous owner owned it and does he know if the head gaskets are still original or not? You can tell by looking at the sides, do they look cleaner than the rest of the block?
if they replaced the radiator and water pump why not the thermostat?
I would guess stat first and air in system.
Good luck!
Old Aug 12, 2015 | 05:07 PM
  #22
june82000's Avatar
Originally Posted by barryt
i dont think he will let me do a bunch testing to his car.
Test only takes a couple minutes after the engine is warmed up
Old Aug 12, 2015 | 08:09 PM
  #23
cappedup's Avatar
Then you aren't going to buy it from him. And it sounds like not many people are going to be interested.
You have no reason 'not' to play a touch tough.
Depends what you are after.
If you have the space to put it, time to play with it, and a fist full of dollars - wave it at him and walk away if he shrugs. Dropping your phone number for when he changes his mind.
Good luck.
Old Aug 13, 2015 | 06:09 AM
  #24
drowssap's Avatar
$500 or walk there are plenty out there.
The gauge in a LR does not normally go up a little, it is usually one of three places, cold, 1/2, or overheated.
USNAVYORDNANCE
May 18, 2015 07:27 PM
CrimsonRavyn
Feb 26, 2012 09:40 PM
azazel_18_2
Jun 29, 2010 05:56 PM
Knuckle Dragger
Aug 5, 2009 05:40 PM
dips
Oct 8, 2007 05:31 AM
