power steering box
RE: power steering box
mike, the universal joint going into the box turns, the input shaft turns also, but nothing else is happening. nothing is moving on the output side.i can turn my wheel all day long in both directions.i believe from a cutaway view in the parts manual, there is a pin on the input shaft and a pin on the output shaft.maybe i broke a pin? art
Sounds like you've broken the box internally. The output shaft has a flat on it where the drop arm is held on by the Nut. So-- there is no possibility of stripping it there. I have the steeringbox as a remanufactured unit for $375.00 plus shipping, and the $160.00 Core charge.
Regards,
Geoman
www.eurotekapg.com
Regards,
Geoman
www.eurotekapg.com
after further review, the universal joint is stripped and the input shaft or spline does not turn. spline is probably bad and stripped also. will get a chance to look at it further tommorow hoprfully out of this wet weather we have been getting up he-ah! i have a steering box on the way and will look over the front end real good. art
DiscoBritney
12-19-2011 06:24 PM
losinov
03-21-2011 08:57 PM
