power steering box
Old May 14, 2007 | 04:46 PM
pennystockart's Avatar
Default power steering box
my steering wheel turns but no imput to the wheels, so i either sheared a pin by my universal joint or my power steering box is broken. any inputs and how hard is it to change the steering box? thanks for your replys in advance. 1995 disco 1! 3.9 liter. art in maine
Old May 15, 2007 | 08:10 AM
Default RE: power steering box
So when you turn your steering wheel, your pitman arm under the steering box doesn't turn??
Check the shaft from the steering whell down to the steering gear box, is the coupeling tight or has it come loose?
Mike
Old May 15, 2007 | 09:54 AM
mike, the universal joint going into the box turns, the input shaft turns also, but nothing else is happening. nothing is moving on the output side.i can turn my wheel all day long in both directions.i believe from a cutaway view in the parts manual, there is a pin on the input shaft and a pin on the output shaft.maybe i broke a pin? art
Old May 15, 2007 | 12:39 PM
geoman's Avatar
Sounds like you've broken the box internally. The output shaft has a flat on it where the drop arm is held on by the Nut. So-- there is no possibility of stripping it there. I have the steeringbox as a remanufactured unit for $375.00 plus shipping, and the $160.00 Core charge.
Regards,
Geoman
www.eurotekapg.com
Old May 17, 2007 | 06:30 PM
after further review, the universal joint is stripped and the input shaft or spline does not turn. spline is probably bad and stripped also. will get a chance to look at it further tommorow hoprfully out of this wet weather we have been getting up he-ah! i have a steering box on the way and will look over the front end real good. art
DiscoBritney
Dec 19, 2011 06:24 PM
losinov
Mar 21, 2011 08:57 PM
discomedic4
Mar 30, 2010 01:19 PM
rlp2011
Mar 13, 2008 04:21 PM
pennystockart
May 21, 2007 07:40 PM
