Power steering fluid
Old Mar 23, 2013 | 08:08 PM
Normd996's Avatar
Default Power steering fluid
Changing my Ps pump on an 03 what fluid should we run as drain out the old stuff
Old Mar 23, 2013 | 08:59 PM
SDinDS's Avatar
Typical power steering fluid.... like Valvoline. DON'T use transmission fluid!!
Old Mar 23, 2013 | 10:00 PM
Valvoline Maxlife power steering fluid.
Old Mar 24, 2013 | 07:56 AM
Normd996's Avatar
Thanks it was topped off with transmission fluid when the pump let go in the parking lot at work
Old Mar 24, 2013 | 09:07 AM
Don't just drain the fluid out, do a proper flush and if you don't know how, after you buy 4 quarts of p/s fluid and some sort of a hand pump, shout and I will walk you thru the process.
Old Mar 25, 2013 | 07:54 AM
Normd996's Avatar
Thanks I will do that, getting a pump from Harbor freight. I'm hoping to this tomorrow night, I will PM you then.
Old Mar 25, 2013 | 09:53 AM
jafir's Avatar
Why not?
http://discoweb.org/forums/showthread.php?t=82736
Old Mar 25, 2013 | 07:58 PM
Thats the wrong way to change the power steering fluid, just remove the return hose from the tank, stick it into a empty gallon jug, have a friend start the engine, you keep the system full, watch the hose, once clean fluid comes out shut off the engine, put hose back, top off system, done.
15min.
You will need 2qts of power steering fluid.
And you can use Dexron III if you want to, its just hydraulic fluid.
jycsalas
Apr 17, 2009 02:21 AM
willlane
Nov 10, 2007 07:33 PM
jdelp
Oct 3, 2007 11:05 AM
discoken
Jul 4, 2007 05:29 PM
nanin
May 12, 2007 10:09 AM
