Power Steering Fluid Bleed?
Old Jul 3, 2009 | 01:15 PM
lipadj46's Avatar
Default Power Steering Fluid Bleed?
In doing my head gaskets I had to empty my PAS fluid. Now when I refill it is there anything specific I need to do to?
Old Jul 3, 2009 | 02:36 PM
How much drained out and how much have you put back in? Is the pump noisey, is the fluid swireling in the bottle?
Old Jul 3, 2009 | 04:16 PM
lipadj46's Avatar
It all drained out that I can see. I had to remove the high pressure hose that went into the bottom of the PAS pump to remove the left cylinder head. Now I have it all together just figuring out how to refill it. I suppose it is just as simple as filling the reservoir to the top?
Old Jul 3, 2009 | 07:47 PM
No, there is a bleed screw on the pump and I believe on the gear box also.
Old Jul 3, 2009 | 09:50 PM
lipadj46's Avatar
I don't see a bleed screw on the pump let me check the Rave CD.
Edit: Found it, it's on the steering box.
Old Jul 4, 2009 | 07:56 AM
Sounds like I got them back wards.
Old Jul 10, 2009 | 09:25 PM
DavidG's Avatar
So how do you bleed it then?
Put tube on bleeder, open, and turn wheel back and forth while keeping reservoir full?
Could this procedure be used to change the fluid totally?
Old Jul 10, 2009 | 10:33 PM
lipadj46's Avatar
I bled it by loosening the bleed screw slightly and having my wife turn the wheel side to side until the air is gone. I put a tub underneath to catch the excess oil.
To change the fluid I would take out the high pressure tube from the bottom of the PAS pump and let it drain then bleed it.
Old Jul 11, 2009 | 08:52 AM
So if you want to bleed the system, suck all the fluid from the reservor, refill it, turn full left and right 2 times, turn the engine off and repeat 2 more times, then on the last refill, ad 1/2 bottle of Lucas and top it off. This is a much better way to do it and you don't get fluid all over the ground.
RegT
Nov 25, 2014 10:32 AM
obnxsh
Aug 28, 2012 07:47 PM
JavaDiscoII
May 29, 2010 04:33 PM
jycsalas
Apr 17, 2009 02:21 AM
flyingalexf68
May 9, 2006 01:51 PM
