Power Steering Fluid and PS Pumps
Old Nov 29, 2016 | 12:56 PM
MaineDisco2's Avatar
Default Power Steering Fluid and PS Pumps
I've read some threads about ATF being used in Disco I's for power steering but that Disco II's take actual PS Fluid. I know the PS pumps are generally not long lived but my Disco II has red fluid in the reservoir and I curious if this is likely ATF and would cause early failure of the pump? I'm installing a new PS pump so I wanted to know if I should flush the PS system completely of the red stuff in favor of clear PS fluid. Any advice would be useful.
Old Nov 29, 2016 | 03:23 PM
Motorhead1's Avatar
I used clear power steering fluid in mine. If you do a search on this site, you'll come up with your own conclusion on what to use. The system calls for the same oil that is used in Honda's, but I couldn't find that at the part store. And I wasn't going to Honda for power steering fluid, so....
Old Nov 29, 2016 | 03:31 PM
OffroadFrance's Avatar
My D2 TD5 is 13 1/2 years old this year and I've always used ATF in the PAS reservoir whether recommended or not. Original pump but had to replace the alu and rubber return pipe as it wore through against the engine sump (common TD5 issue). IMO sometimes one can be too fussy and the PAS pump is little different to the autobox. PAS fluid IMHO is yet another marketing ploy a bit like genuine Landrover parts vs others.
Old Nov 30, 2016 | 01:13 AM
jfall's Avatar
That pump can make a lot of noise
Old Dec 1, 2016 | 02:54 PM
Upon further inspection my PS pump it piped into and out of the auxiliary cooler for the transmission. I assume this is why I'm getting ATF in the reservoir but the routing of the PS lines into the cooler is not reflected in the service manual. Anyone know if this is the typical set-up?
Hi, this is not a typical setup for a D2, wel at least not for a TD5. Are you positive you are looking at the fluid lines correctly? it may be a variant D2 destined for very hot climates (middle east etc) but my D2 is a LHD and designed for the southern Americas and the temperature there can be from very hot to sub zero. It does sound very strange to me but I'm sometimes wrong.
Old Dec 1, 2016 | 05:08 PM
LR03NJ's Avatar
Its not routed the same. Its just went under the cooler and looped back. Its hardly visible under or above because the line is underneath the oil cooler. With regards to fluid, i usr the dark green fluid, pentosin.
Old Dec 1, 2016 | 05:29 PM
number9's Avatar
Power steering and ACE
Texaco Cold Climate PSF 14315.
LR put out a lubrication/fluid list some time ago that said ATF fine to use in ACE depending upon ambient temps and assumed seals in both PAS/ACE wouldn't be compromised by the ATF. There may be some slightly better lubrication qualities of one fluid over another that could reduce internal metal wear of pump or gear as the same applies to motor oils. If it makes you feel better purchasing the best high dollar fluids or living in a N/S polar region during the extremely dark/cold times it may work better for you.
Yes that appears correct. I'm individually an *** and cannot see straight. They do go under the cooler. my eyes deceived me. I will consider flushing out the whole system for the greenish ACE fluid.
pprussell
May 7, 2013 02:45 PM
lipadj46
Oct 7, 2010 11:19 AM
jycsalas
Apr 17, 2009 02:21 AM
Hare
Sep 16, 2008 07:26 PM
rinmud
Aug 12, 2006 07:12 PM
