Power Steering Left Hesitation
I bought a 99 D2 this week with 96k miles on it and have replaced 1 O2 sensor and a magical $260 key. Not bad so far but...
I'm noticing that when I turn to the left at times, the steering feels like it no longer has power steering for about 1 second and then goes back to power steering. It's happened about 5 times and has never happened to the right. I just had the power steering flushed and filled (it was over-filled when I bought it) and it's happened 1 time in a 24 hour period since then. Any thoughts? Rack, belt, pump?
Thanks!
Mark
Thanks!
Mark
on
As a side note, if you are around 100,000 miles, you should replace all 4 02's to regain some old power and balance out your air fuel ratio.
As for the steering do a p/s fluid flush using 5 quarts of p/s fluid and 1 bottle of Lucas.
Send me your number and I'll walk you thru it.
Might also want to follow my 60K service list, posted at the top of the Discovery section, and get that new truck current on all it's needs
Do you know what brand of power steering fluid they used?
I recently read in a mechanics magazine that some manufacturers require a power steering fluid with "X" ingredients and that a lower quality power steering fluid was burning up power steering pumps and acting just like yours is.
So here is what I would do, take it back to the shop and find out what brand of power steering fluid they used.
Then either have them do it again using a different (and better) brand and that you will pay for the fluid but the labor is on them.
Remember that not all fluids are equal.
Take care of this ASAP or you will loose your power steering pump.
Update: They used Royal Purple 01326 Max EZ.
I also notices that on startup, the system seems to require slightly more muscle (probably has less pressure) than when driving at a slightly higher RPM. I idle around 850 RPM.
This weekend, I'm doing plugs, wires and 3 more O2 sensors. Sounds like I might also just replace the PS pump and move on.
Thanks!
Mark
Thanks!
Mark
Believe it or not these vehicles are picky enough about fluids that synthetic may not be the best choice. It will like some fluids and others will cause problems. I have never had any problems with Royal Purple but I also have never tried RP power steering fluid in a Rover.
Mike - could he have an air bubble somewhere in the system causing this?
johnnyjohnny
09-26-2019 09:37 PM
DiscoBritney
12-19-2011 06:24 PM
losinov
03-21-2011 08:57 PM
jycsalas
04-17-2009 02:21 AM
