Power Steering pump issues...
Old Nov 16, 2011 | 01:44 AM
cobbcj7's Avatar
Angry Power Steering pump issues...
In responce to a pryor post I made, im still getting bad results..
My first attempt, since I couldnt find a factory new gasket, I appemted to just use RTV..
As stated in my last post, the RTV inhibited the movement of the pump pully and didnt work well..
That Failed obviously, so I took other measures
I could only find a 1/32 gasket rudbber/composite gasket and we installed that..
In both attempts, I have yet to get any consistent power steering feel..
On my second attempt with the known larger gasket, I get a bettter steering wheel performance, but still its terrible..
With my first run with just RTV I got sparatic bursts of normal steering.. but with second attempt with larger gasket, Im getting none of that, just ok/crappy steering, but not the hard as hell steering..
Am I just dealng with a blown pump all together?? I got absolutely no gear box whinning noise on the larger gastket attempt which makes me think the pump went bad...
Old Nov 16, 2011 | 01:32 PM
Hay's Avatar
Hay
Did you bleed the air from the steering box.
Old Nov 29, 2011 | 01:17 PM
G4-Rover's Avatar
4th Gear
Does it whine the whole time the engine is running? If so it's a bad pump just had to replace mine about a 1-2hr job due to all the stuff you have to remove to even get to the pump.
Old Nov 29, 2011 | 10:15 PM
lordmorpheus's Avatar
G4- Where in Mo are you from?
Old Dec 5, 2011 | 12:01 PM
G4-Rover's Avatar
4th Gear
lordmorpheus I live in a small town near Fort Leonard Wood.
Old Dec 5, 2011 | 06:26 PM
Lol, I pass the turn off for FLW every time I go visit the in-laws in Rolla, and I bought my Landy from a gal on base, then flat-bedded back to Columbia.
Nice to see another member from Missouri!
Andy2Rover
Oct 15, 2024 05:35 PM
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
losinov
Mar 21, 2011 08:57 PM
Discodude
Jan 26, 2011 09:46 PM
