Power Steering Pump Leak Fixed
Old Jul 9, 2011 | 10:16 PM
0304Disco's Avatar
Default Power Steering Pump Leak Fixed
The phrase three times is a charm worked for me when resealing my PSP housing.
It had a leak from the housing just in front of the reservor supply hose. I unbolted the four bolts holding the housing together and split the housing. The thin plastic gasket was in good shape so I thought RTV would seal it up. WRONG. Each time I cleaned all internal components with mineral spirits and made sure no residual PSP fluid was present.
The first RTV I used was premetex Ultra Black. The housing will only take about 4 foot pounds of torque before the PSP shaft has some resistance when turning. Any more and it will drag really good and probably break shortly after. Anyways, this started leaking within seconds of filling with fluid.
The Second RTV I used was premetex Transfer Case RTV. The housing will only take about 4 foot pounds of torque before the PSP shaft has some resistance when turning. Any more and it will drag really good and probably break shortly after. Anyways, this started leaking within seconds of filling with fluid.
THE FIX:
Went to NAPA and bought some fiber gasket material. This material is about .032 thick so you don't have the problem of locking up the housing with to much torque. Took my old plastic gasket and traced it on the new material. Used an exacto knife cut out. installed gasket onto housing using NO RTV and tighted bolts to 12 foot pounds.
Hope this works for you as it saved me 400$$.
Old Jul 9, 2011 | 10:52 PM
Sweet!!
Thank you for posting.
Old Jul 10, 2011 | 11:55 AM
DiscoRover007's Avatar
That's what I did too man. Holds up like a champ.
Old Oct 1, 2011 | 12:39 PM
sebastian's Avatar
4wd High
Lightbulb Steering pump leak. tutorial how to fix it.
Hello, here is a step by step tutorial how to fix the power steering pump leak on. Gasket avaible on Ebay for £11.99
Land rover Discovery
Land rover Freelander
Land rover LR3
Land rover Range Rover
suitable also for:
Rover 220 Petrol (Turbo Non-Turbo) (1994 to 1999)
Rover 220 Diesel (Turbo Non-Turbo) (1996 to 1999)
Rover 420 Petrol (Turbo Non-Turbo) (1994 to 1999)
Rover 420 Diesel (Turbo Non-Turbo) (1996 to 1999)
Rover 620 Petrol (Turbo Only) (1992 to 1999)
Rover 620 Diesel (Turbo Non-Turbo) (1996 to 1999)
Rover 820 Petrol (Turbo Non-Turbo) (1994 to 1999)
MG ZR Diesel (1999 to current)
MG ZS Diesel (1999 to current)
Old Oct 1, 2011 | 12:40 PM
sebastian's Avatar
4wd High
Default Steering pump leak. tutorial how to fix it. part 2
Old Dec 22, 2011 | 01:42 PM
cobbcj7's Avatar
Not sure what those pictures are, but that is not an 04 Discovery power steering pump for the 4.6L and I had a leak and put the .032 gasket in mine and no power steering what so ever.. I bled the system and everything
Old Dec 19, 2013 | 01:13 PM
Honey Badger's Avatar
3rd Gear
How is the homemade gasket holding up? I'm about to try the same fix on mine
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
OZTRAX
Dec 5, 2012 11:55 PM
losinov
Mar 21, 2011 08:57 PM
mburnett
Apr 7, 2008 08:50 PM
