Power steering pump replaced. Immediate leak.
Old Oct 9, 2014 | 01:18 AM
Echoman's Avatar
Default Power steering pump replaced. Immediate leak.
Hi again guys, I replaced my power steering pump about two weeks ago with a remanufacutured pump from the local auto parts store. My original pump's gasket blew out on a trip out of town and I had no choice, but to use the local parts store. Anyway, about a week later I noticed a small puddle of PS fluid under the truck. It looks like it's coming down from the new pump. I can't tell if it's the suction hose or the pump itself since it seems to be running down that lower hose. I degreased everything, but can't seen to find the source. My fear is that it's the new pump. Is it possible that I over torqued something by hand causing the pump gasket to fail. I wasn't working with a torque wrench available. Are the reman pumps apt to fail? I'm not noticing any fluid loss in the reservoir yet, so it's a slow leak. Pretty frustrating, but any advice or knowledge on this would really be appreciated. Thanks for any help.
Old Oct 9, 2014 | 06:41 AM
drowssap's Avatar
it could be coming from the return line sometimes the end of that hose gets weak, you can try taking a little off the line and re-installing it.
Old Oct 9, 2014 | 07:37 AM
TRIARII's Avatar
Ive heard countless people say how unreliable rebuilt power steering pumps are. I recently replaced my worn out pump, reservoir and 2 PS hoses and my leak is gone. I noticed that Rovers North sells rebuilt pumps for $349 but for an extra $30 you can buy one of their brand new Proline pumps and rest assured. When you replaced your pump you probably should have at least replaced the 2 rubber hoses that connect to the reservoir. Another common area for leaks is the 3rd hose that is half metal and part rubber. It weaves behind the radiator I believe and is harder to access without lifting up the radiator.
Old Oct 9, 2014 | 09:51 AM
ZGPhoto's Avatar
Could be a loose hose, but it's pretty likely it's the pump. The really cheap ones fail all the time.
Old Oct 10, 2014 | 08:23 PM
Echoman's Avatar
Thanks guys, I loosened the return line clamp and adjusted/ tightened it. I didn't see any fluid on the floor today. I'll have to look underneath later. I really hope that was it. I'll probably order a new hose just in case. Thanks again.
Old Oct 10, 2014 | 09:30 PM
TRIARII's Avatar
New PS Pump:
PUMP POWER STEERING DISCOVERY II, PLH248, QVB500080 - Rovers North - Classic Land Rover Parts
Pump to reservoir hose:
Box to reservoir hose:
Ask for Zack Griswold (ZGPhoto) cause he may hook you up with a good deal
Old Oct 12, 2014 | 08:45 PM
shanechevelle's Avatar
I took mine apart and sealed it up myself.
sammytray
Jan 5, 2015 01:44 PM
james.martin1
Sep 30, 2014 06:33 AM
parkerlander
Aug 28, 2012 11:51 AM
railroader
Feb 19, 2012 04:14 PM
itsblair
Feb 16, 2007 06:25 PM
