Power steering pump replacement
Old Nov 12, 2013 | 10:42 AM
MillerMonteSS's Avatar
Default Power steering pump replacement
2004 Discovery SE7
I found this video of a pump replacement and wanted to be sure that it would work for my 2004. What do you think?
It looks pretty straightforward and I have found a pump within 20 miles of my house.
Old Nov 13, 2013 | 07:06 AM
kenk's Avatar
Thats pretty much it. Some things I found when i did mine about a week ago: if you can get the fan off easily, it will make things easier. Break loose the pulley bults before you remove the belt. My bracket that the pump mounts in did not just pop right off. it took a little carefull prying. (dont think it was ever off)
Old Nov 13, 2013 | 10:42 AM
Sweet! I appreciate that! I'll be trying this out at around 2 p.m. EST.
Old Nov 13, 2013 | 01:54 PM
04duxlr's Avatar
I tried to pull my PS pump out to rebuild it and had no luck because the fan wouldn't come loose. I couldn't get the bracket off the stud with the fan in the way. I don't like the idea of cutting it like the guy in the video did. Besides, my fan clutch seems a little loose so I'm going to need to get it off anyway.
I didn't watch the whole video so I'm not sure if he goes through bleeding the system but I read in a post about someone running a hose from the nipple on the steering box up into the reservoir which sounds like a great idea. That way you can keep turning the wheel without worrying about running out of fluid.
Old Nov 13, 2013 | 04:17 PM
Just finished up! It worked pretty much exactly as the video described. The replacement pump used a different pulley back. It had one nut holding the pulley on. Was one of the easiest PS pump replacements I've ever done.
bustedwheel
Oct 18, 2019 04:21 PM
logic2
Aug 31, 2013 08:38 PM
0304Disco
Mar 26, 2012 03:48 PM
bustedwheel
Mar 14, 2012 06:49 AM
hhalimi
Jan 24, 2012 09:24 AM
