Power steering question
98 D1, V8i
I have a bad leak that appears to be the seal where the steering column shaft enters the steering box. Is there a seal around the shaft there that commonly fails?
Can it be replaced by just disconnecting the steering column lower UJ or do I have to remove the box and withdraw the splined shaft from the power steering box?
Any magic sealers that will solve this? lol
thanks
Alan
thanks
Alan
Other than a stop leak, you can replace that seal but it is a 50/50 if it will work.
Make sure that you only use 1/2 bottle of stop leak, any more and you risk plugging the system and burning up your power steering pump.
I used Dexron III with stop leak to cure my PS leak 2 years ago.
You must give the stop leak time to work, just use it as a top off fluid until half of the bottle is gone, then keep topping up with normal ATF for several weeks until the stop leak works its way in.
johnnyjohnny
09-26-2019 10:37 PM
DiscoBritney
12-19-2011 07:24 PM
losinov
03-21-2011 09:57 PM
jycsalas
04-17-2009 03:21 AM
