Power steering question
Old Aug 23, 2009 | 11:53 AM
alanroberts50's Avatar
Default Power steering question
98 D1, V8i
I have a bad leak that appears to be the seal where the steering column shaft enters the steering box. Is there a seal around the shaft there that commonly fails?
Can it be replaced by just disconnecting the steering column lower UJ or do I have to remove the box and withdraw the splined shaft from the power steering box?
Any magic sealers that will solve this? lol
thanks
Alan
Old Aug 23, 2009 | 11:56 AM
lipadj46's Avatar
Try 1/3 bottle of white shepards. I'm fighting a leaky PAS system now. It's a losing battle.
Old Aug 23, 2009 | 12:26 PM
Other than a stop leak, you can replace that seal but it is a 50/50 if it will work.
Make sure that you only use 1/2 bottle of stop leak, any more and you risk plugging the system and burning up your power steering pump.
I used Dexron III with stop leak to cure my PS leak 2 years ago.
You must give the stop leak time to work, just use it as a top off fluid until half of the bottle is gone, then keep topping up with normal ATF for several weeks until the stop leak works its way in.
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
