Pressure testing D11
Looking for some insight into pressure testing for bad head gaskets.This is on a 03 D11 with 98k, so prime turf for HG failures. The tester was out after the throttle body heater failed and was replaced.
Post TBH, when I test up to 15psi, I'm seeing coolant slowly drip from the back of the motor. The rig will hold 15psi well though (>10mins). As I can see the leak, I would expect to see the pressure drop slowly. I'd infer the leak must be relatively slow. With the bad TBH, 10psi would drain away in ~5mins with coolant clearly hissing out.
I know this is more a when, than if, call on replacement, but has anyone run this test before replacing HGs and seen it hold pressure OK?
TIA,
Paul
TIA,
Paul
I would replace the head gaskets before you get more damage.
Not easy or even pleasant.
But you can do it.
1997 Land Rover replace catalytic converter and head gaskets
Flickr: Landroverdude2's Photostream
But you can do it.
