Pressure testing D11
Old Nov 25, 2012 | 08:48 AM
bmt213a's Avatar
Default Pressure testing D11
Looking for some insight into pressure testing for bad head gaskets.This is on a 03 D11 with 98k, so prime turf for HG failures. The tester was out after the throttle body heater failed and was replaced.
Post TBH, when I test up to 15psi, I'm seeing coolant slowly drip from the back of the motor. The rig will hold 15psi well though (>10mins). As I can see the leak, I would expect to see the pressure drop slowly. I'd infer the leak must be relatively slow. With the bad TBH, 10psi would drain away in ~5mins with coolant clearly hissing out.
I know this is more a when, than if, call on replacement, but has anyone run this test before replacing HGs and seen it hold pressure OK?
TIA,
Paul
Old Nov 25, 2012 | 10:56 AM
blamo's Avatar
Lots of headgaskets fail on driver side rear . Just sayin blamo
Old Nov 25, 2012 | 02:30 PM
jfall's Avatar
I would replace the head gaskets before you get more damage.
Not easy or even pleasant.
But you can do it.
1997 Land Rover replace catalytic converter and head gaskets
Flickr: Landroverdude2's Photostream
Old Nov 26, 2012 | 07:24 AM
drowssap's Avatar
head gasket , freeze plug or valley pan gasket are your only options
Old Nov 26, 2012 | 09:03 AM
jeffh's Avatar
If you are seeing coolant at 15psi on a cold engine I would STOP driving before you toast your engine. Either do the work yourself or get it to a GOOD indie shop. DO NOT play around with the guessing game of what if's unless you want to replace your motor.
Phatrowles
Feb 12, 2025 10:29 AM
dkdirt63
Jul 12, 2012 06:25 PM
marshman442
Aug 27, 2011 09:07 AM
landover
Dec 14, 2010 10:42 PM
avking
Jan 9, 2009 09:24 AM
