Prestone Green Availability and Other Coolant Options
Old Aug 18, 2022 | 07:33 PM
acg's Avatar
acg
Pentosin Pentofrost SF (pink) for me too. You can get it at Rock Auto.
Old Aug 18, 2022 | 08:40 PM
mln01's Avatar
This. Any Walmart. Every Walmart.Prestone Green Availability and Other Coolant Options-photo287.jpg
Old Aug 25, 2022 | 05:07 AM
neuropathy's Avatar
Hey Brandon, just wondering if you're using Zerex G48? Do you aim for a 50/50 mixture? I'm in a similar climate here. I help with a relative's E46, so I wouldn't mind using a coolant that can be used in both vehicles, but I really prefer to use whatever is safest for the engine and hopefully lasts a long time, rather than whatever is easiest for me.
Old Aug 25, 2022 | 06:18 AM
Dweeb Discovery's Avatar
Originally Posted by neuropathy
Hey Brandon, just wondering if you're using Zerex G48? ... I help with a relative's E46, so I wouldn't mind using a coolant that can be used in both vehicles, but I really prefer to use whatever is safest for the engine and hopefully lasts a long time, rather than whatever is easiest for me.
Prestone. Don't overcomplicate this.
... Do you aim for a 50/50 mixture? I'm in a similar climate here. ...
Climate is irrelevant. 50/50
Old Aug 25, 2022 | 11:07 AM
Brandon318's Avatar
I use BMW's actual coolant. It's surprisingly about the same price as any other coolant and concentrated. So yes, 50/50 with distilled of course. Prestone works great too. I used to be deep in the BMW M world (E46/E39/E36/E30/E28) before leaving the brand for Land Rover, and BMW's coolant (re-boxed Zerex) works extremely well with aluminum components. Also, its blue color makes spotting leaks really easy, for me at least. It dries to a super bright bright blue that stands out really well.
Old Aug 25, 2022 | 09:46 PM
Sandman614's Avatar
Originally Posted by dtmbinb
Any of those are fine. Just don't mix with other types. I use VW/Audi G13 because I use it in my Audi as well. Just easier that way. Zerex G-05 is good too. Just flush and use any of the above consistently. All good.
I use Zerex Asian(Toyota) in both the Rover and my Tacoma. The key is a clean flush and don't let any dimwits do a "Courtesy Check" or" top off your fluids"
Old Aug 26, 2022 | 07:24 PM
mr. choodles's Avatar
Folks, what about running distilled water + water wetter or equivalent? I know it may not be appropriate for NC winters, but what's wrong with running that combo during warm months?
Old Aug 27, 2022 | 07:43 AM
mln01's Avatar
As far as cooling, there's nothing wrong with running water. But, among other things, antifreeze inhibits cooling system corrosion, so that's why I personally would not run straight water (even with water wetter). And of course antifreeze raises the boiling point of the coolant as well as lowering the freezing point, but that shouldn't matter much in a pressurized system running at "normal" operating temps.
Old Aug 27, 2022 | 10:03 AM
Interesting... I thought Water Wetter inhibited corrosion. Btw, all my buddies who track cars or bikes use water wetter + water combo. Interesting read: https://www.pegasusautoracing.com/do...ocID=TECH00010
Old Aug 28, 2022 | 10:55 AM
Sean Maginness's Avatar
Same here. Zerex Asian (red in color) easy to source and works.
freepower
Dec 2, 2021 10:42 AM
flanker6
Dec 14, 2018 05:40 AM
robert.juric
Mar 27, 2015 05:05 PM
gribur
Feb 7, 2015 10:44 PM
RROJ
23
Dec 1, 2010 12:53 AM
