Prestone Green Availability and Other Coolant Options
Hey Brandon, just wondering if you're using Zerex G48? Do you aim for a 50/50 mixture? I'm in a similar climate here. I help with a relative's E46, so I wouldn't mind using a coolant that can be used in both vehicles, but I really prefer to use whatever is safest for the engine and hopefully lasts a long time, rather than whatever is easiest for me.
Hey Brandon, just wondering if you're using Zerex G48? ... I help with a relative's E46, so I wouldn't mind using a coolant that can be used in both vehicles, but I really prefer to use whatever is safest for the engine and hopefully lasts a long time, rather than whatever is easiest for me.
Folks, what about running distilled water + water wetter or equivalent? I know it may not be appropriate for NC winters, but what's wrong with running that combo during warm months?
As far as cooling, there's nothing wrong with running water. But, among other things, antifreeze inhibits cooling system corrosion, so that's why I personally would not run straight water (even with water wetter). And of course antifreeze raises the boiling point of the coolant as well as lowering the freezing point, but that shouldn't matter much in a pressurized system running at "normal" operating temps.
Same here. Zerex Asian (red in color) easy to source and works.
RROJ
23
Dec 1, 2010 12:53 AM
