Preventative Maintenance for a 2004 Disco?
Old Jan 27, 2013 | 07:50 PM
criticalmassey's Avatar
Default Preventative Maintenance for a 2004 Disco?
Hi All,
Just bought a super clean 2004 Disco with 96k miles. Super clean history, nearly no issues to date. That said, even though super clean and no issues, at 96K miles what would the expert opinion be on what preventative maintenance should be done to keep this rolling another 100k?
Thanks so much!
Old Jan 27, 2013 | 08:00 PM
Colorado David's Avatar
https://landroverforums.com/forum/di...service-29020/
The oil and filter recommendations have probably changed since this sticky was written. Make sure you never overheat and go out to the garage right now and see if it has serviceable u-joints on the front propshaft. Rebuild or replace the front propshaft if it doesn't. The factory propshaft will have a single grease zerk on the differential end. It needs to be serviceable at all u-joints.
Here's the propshaft topic; https://landroverforums.com/forum/ge...rebuild-29302/
Old Jan 27, 2013 | 09:24 PM
Over heat = above 50% on gauge. Plug in a scanner or Ultra Gauge to see the actual temps. And the factory manual set is called the RAVE, free download links.
Old Jan 27, 2013 | 09:27 PM
ZGPhoto's Avatar
I think the only true preventative maintenance on a Disco is to not buy one in the first place...
Old Jan 28, 2013 | 01:29 PM
buick215's Avatar
It will also prevent you from going insane.
dusty1
Aug 25, 2013 07:02 PM
north_nm_rover
Mar 27, 2013 01:44 PM
Pwn777
Mar 31, 2010 09:20 AM
mwindth
Feb 28, 2010 11:11 PM
Disbet
Jun 11, 2009 08:58 AM
