pro active parts replacement
Old May 25, 2015 | 08:28 AM
Celto 4's Avatar
Default pro active parts replacement
i am going to replace the water pump on my o3 and i was wondering what the thoughts are on the fan clutch @ 156.000 also am going to to Rotella oil and just wondered which one everyone suggests thanks
Old May 25, 2015 | 09:29 PM
TRIARII's Avatar
Water pump, water pump gasket, thermostate, maybe the cooling hoses and throttle body heater plate and if you wanted to replace the fan and clutch then thats not a bad idea. Inspect the cooling fan. See if it feels brittle or has any visible signs of wear or cracks. If so replace that fan before it decides to wreck havoc in your engine bay and send shrapnel everywhere.
Old May 26, 2015 | 06:20 AM
drowssap's Avatar
if you are going to replace your water pump find a fan from and 99-02, that way you can replace just the clutch. 03-04 the fan and clutch are a one piece uint
Old May 27, 2015 | 07:20 AM
Celto 4's Avatar
thanks yes doing water pump all hoses and stat fan still seems in good shape will do that down the line anyone found a good price on lower windshield cowl? atlantic british seems best price ive found
icyhot201
Nov 27, 2012 12:32 AM
thehun
Sep 8, 2012 08:01 PM
cfp_ivan
Dec 20, 2011 10:34 AM
Spensive
Mar 19, 2010 06:36 AM
HoustonRoverEN
Apr 3, 2007 05:03 AM
