Probably Head Gasket
Old Jul 9, 2013 | 10:25 PM
jfall's Avatar
You probably got air into the coolant system from gasses entering from a bad head gasket.
As long as you replace the head gaskets, you'll probably be fine.
As long as a cylinder liner did not come loose.
Sorry this had to happen to you.
I slept in my rover for hours with the engine on and the A/C running - to save money on hotels in Boulder, CO. Hotels go up like crazy in June.
Old Jul 9, 2013 | 10:27 PM
jfall's Avatar
Yeah, that is just a cooked head gasket sound.
Don't drive it.
Just replace the head gasket.
Look for a groove in the block or head.
You are probably OK - but that blew out pretty quick.
I could not hear liner rap.
There is also a squeak when the engine is turned off.
Fan clutch may be ready to let go.
Old Jul 9, 2013 | 10:29 PM
jfall's Avatar
Good job on posting a video!
Yeah, a chunk of the head gasket is gone and the cylinder is losing compression.
You could find the cylinder with a compression test..
But, that's a waste of time.
You have heads to pull off.
Just leave the manifolds bolted to the Y pipe and take out the bolts manifolds to heads - carefully - back and forth as if you try to just remove them and they resist, then the bolts will snap.
Old Jul 9, 2013 | 10:30 PM
jfall's Avatar
Here are some pictures.
With summer here, all you need is a parking lot and a good trouble light if you are working at night.
Old Jul 9, 2013 | 10:31 PM
jfall's Avatar
Flickr: Landroverdude2's Photostream
Old Jul 10, 2013 | 01:26 AM
make that a 3/8 wrench, the 1/2 inch digital I had on the bench won't go low enough for the some of the torques.
Bug spray. sports drink, and a roof is sure handy, plenty of rain delays in my project.
Old Jul 10, 2013 | 08:12 AM
Aaron Sandland's Avatar
just want to thank everyone for all the opinions and input. I'll be starting the project this weekend and see how it goes.
Old Jul 10, 2013 | 11:29 AM
Take lots of pix. Confirm any and all torque settings and values. Plastic baggies with note cards help.
elboy0712
Feb 7, 2010 07:45 AM
tornado_735
Mar 3, 2009 02:34 PM
discobob
Dec 26, 2008 07:55 AM
mattrickman
Dec 5, 2008 12:16 PM
S4poor
Aug 9, 2007 05:49 PM
