Problems with my DII
Old Jul 23, 2013 | 10:26 AM
BessietheRover's Avatar
So the problem translates according to the codes as a 4th cylinder misfire, anyone have a thread that they could direct me to to fix it/advice?
Old Jul 23, 2013 | 10:47 AM
drowssap's Avatar
you could start with the easy stuff replace the plugs and wires, do a search for Kingsborne Ignition Spark Plug Wires Sets made in the USA good wires really cheap pricing go with at least an 8mm wire.
Old Jul 23, 2013 | 10:54 AM
Ok thanks so much
Old Jul 26, 2013 | 08:21 AM
Replaced wires and works beautifully, thanks for all the help!
Old Jul 26, 2013 | 08:29 AM
And thank you for the feedback. You are a proud member of the Beluga Black tribe. Wax roof often....
Old Jul 26, 2013 | 02:17 PM
Haha will do, AWOO!
Old Jul 28, 2013 | 03:30 PM
BroGrim's Avatar
3rd Gear
Im having the same knarled sound when Im driving at higher speeds. But I have a vibration is going on as well. My hope is that I need new tires. Because it happens only at certain speeds. Does that sound plausable or is it a wheel hub or worse? I have a 04 Discovery 2.
Old Jul 28, 2013 | 03:34 PM
BroGrim's Avatar
3rd Gear
Also I had a misfire code in my #2 cylinder. Along with super heating and water out the pipe. Had to replace Heads. Do you have any of the other issues?
Old Jul 28, 2013 | 03:39 PM
First go to an auto zone or if you have an ob reader use that so you can pinpoint what is actually wrong. It could be a misfire in another cylinder which is causing that vibration or it could just be your tires. Due that and then see where you get, good luck.
Old Jul 28, 2013 | 03:46 PM
Sounds like all the issues I've had in the past year
-overheating: replaced head gaskets and thermostat July 2012
-crack in the radiator: replace radiator August 2012
-vibrations in driving and steering pulling: new tires and alignment April 2013
-car wouldn't turn over: replaced battery (not the problem) replaced crank position sensor (the problem) May 2013
-vibrations in steering and braking: replaced warped rotors and brake pads in the front July 2013
-service engine light with cylinder 4 misfire: replaced wires July 2013
