Prop shaft joint play
Old May 8, 2017 | 07:54 PM
UncleDirtnap's Avatar
Default Prop shaft joint play
i got a fancy new prop shaft in February- spicer u joints, all nice and balanced. I have had a vibration and speed dependent clicking that has gotten really bad over the past week. I was under the truck evaluating things and noticed some play in the rear of the prop shaft.
i put up a video on YouTube:
https://youtu.be/K6J6mBGll4E
I can't quite figure out if this is u joint play or normal double joint play. Anyone want to share their wisdom?
thanks in advance!
-RJ
Old May 8, 2017 | 08:06 PM
Fallstaff's Avatar
Looks pretty upsetting to me!
Old May 8, 2017 | 08:21 PM
LR03NJ's Avatar
That is the double cardan joint. The bearing is shut. Can cause vibration and clunking sound or similar to broken gear sound.
Old May 8, 2017 | 08:36 PM
Luckyjayb's Avatar
May I ask the big question at hand....where did you get the driveshaft and what brand and have you greased it regularly?
Old May 8, 2017 | 09:07 PM
i got it from Dynamic Driveline out of Alabama. I was pretty impressed out of the box- looked burly as heck and was very smooth running.
i greased it when I put it in, but honestly haven't touched it sense. I was going to hit it when I did oil changes, and I'm still about 800 miles away yet. The front joint is rock solid, it's just the rear. I'm not sure what I could have done.....
I called them this afternoon about the warranty, and they were great. I probably won't take advantage of it and will just source ujoints locally and do them myself. I can't spare the truck for the time it would take to send this to them and get it back.
-rj
Old May 8, 2017 | 10:33 PM
Luckyjayb's Avatar
-rj
you mean Arkansas? If it's the one I'm thinking of, they have an eBay store and build heavy duty d2 shafts but they are in Arkansas
Old May 9, 2017 | 06:44 AM
Paul Grant's Avatar
Not looking good. Figure it out before this ends up as the result....
Old May 9, 2017 | 09:30 AM
UPDATE! First, I think that I may an idiot and entirely at fault.
I took out my prop shaft today, and the u joints are all solid, but my centering ball is toast.
I had looked up my propshaft order when I started this ordeal, and I remember the description of '5 grease fittings'. I looked the shaft over and only found 4, but found something on the centering ball that is apparently a grease fitting that I completely overlooked.
How do you grease those things? Im obviously going to replace it, but once I do....
In the end, Dynamic Driveline (yes, or Arkansas. All those deep south states look the same ) makes great, heavy duty propshafts and stand by their work. Their clients sometimes make dumb mistakes.
-rj
Old May 9, 2017 | 09:44 AM
abran's Avatar
You need a needle fitting on your grease gun
Alex_M
Sep 7, 2024 05:21 PM
xmarksit
Nov 26, 2013 08:37 AM
thelod
Jan 5, 2013 01:44 AM
javasteve
Jul 9, 2012 07:26 AM
Schaefer.v
Aug 12, 2010 11:43 PM
