PS pump rebuild
Old Nov 20, 2019 | 10:05 AM
zuke's Avatar
Default PS pump rebuild
I got a leak coming from my ps pump. Before I buy a new one, I remember somebody talking about the option of replacing just the seals. Anybody able to point me to process/part numbers?
Old Nov 20, 2019 | 04:12 PM
Llamasayswhat's Avatar
Are you sure it is the pump? The hose that feeds the bottom of the pump is a common leak point
Old Nov 20, 2019 | 05:55 PM
Extinct's Avatar
9 times out of ten it is the gasket - ebay has them pretty cheap. If it is the front bearing worn out you will need a press to get it apart, do you have one?
Old Nov 20, 2019 | 08:30 PM
Fast951's Avatar
The shaft on your existing PS pump can wear and shear which will cause the pump pulley to walk out and throw the serp belt leaving you stranded. For the price of new I would recommend you just replace the pump.
Old Nov 20, 2019 | 11:04 PM
User's Avatar
agreed got stranded by a PS pump while in Chicago
NOT FUN driving without power steering downtown
joshjellel
Feb 16, 2015 10:53 AM
j.dstasio
Mar 24, 2013 08:11 PM
antichrist
Apr 26, 2011 02:00 PM
kenk
Aug 1, 2010 09:40 AM
ljdiscovery
Oct 29, 2009 09:47 PM
