Pulleys
Old Dec 5, 2017 | 09:33 PM
Carolynsdisco2's Avatar
Default Pulleys
So. Disco 2 lovers...what is the best the correct and easiest way to make sure the pulleys are lined up?
Old Dec 5, 2017 | 11:36 PM
abran's Avatar
Get a laser and shims that are .00001 mm thick and start putting them behind each pulley until that are all within .0000000001 mm of each other.
or, bolt everything up and put a belt on it.
Old Dec 6, 2017 | 08:55 AM
Lisa Bunch's Avatar
There is no alignment necessary, if you have belt problems your pulley bearings could be worn. This could cause the belt to crab off track or slip off completely. Buy a replacement belt, check the pulleys by hand for wobble/excess movement, replace worn pulleys, keep old belt as spare (if not damaged).
Old Dec 6, 2017 | 08:58 AM
abran's Avatar
That was more helpful than my response...
Old Dec 6, 2017 | 09:33 AM
dgi 07's Avatar
You've been here too long. The sarcasm is slowly overtaking you!!!
Old Dec 6, 2017 | 11:12 AM
abran's Avatar
I usually try to edit myself, most of the time I type out the response but don’t send it.
that one slipped through.
Old Dec 6, 2017 | 01:48 PM
LR03NJ's Avatar
lol
Old Dec 6, 2017 | 02:00 PM
mollusc's Avatar
Bolt them on and eyeball them. Just make sure that you don't mount any of the pulleys back to front, so that they're misaligned and eat up your serpentine belt very very quickly. DAMHIK.
It's really obvious when they're backwards, but if you're in a hurry you might miss it...
WillRove
Feb 22, 2013 06:04 AM
seb1755
Jul 31, 2011 10:03 PM
malibutj
May 25, 2011 01:46 PM
73S3IP
Aug 10, 2009 08:46 AM
Jawbox
Oct 26, 2008 10:05 AM
