Pulling 99 cdl today.
Old Oct 15, 2013 | 01:42 PM
White Rover's Avatar
Default Pulling 99 cdl today.
I'm pulling a 99 cdl to put in my 03. My question is do i have to drop the exhaust to pull the front part of the transfer case? Any help is appricated.
Thanks weston
Old Oct 15, 2013 | 02:14 PM
dr. mordo's Avatar
If you're just pulling the CDL and not the t-case, you do it all thru the center console. I might have gotten under twice to work something loose.
Also, don't just pull the shifter, also pull the aluminum housing beneath it, and get every piece of hardware that comes with it. It should look like this, but also you need the pins and clips to connect to the t-case:
Good luck with this. I thought it was a pretty major pain in the *** to install in my 01.
Old Oct 15, 2013 | 02:35 PM
I plan on pulling the whole front of the transfer case off to put in my 03 since it has the non locking cdl. Thanks for the info on the shifter ill need to get all of that once i get this part of the transfer case swapped over!
Old Oct 15, 2013 | 02:36 PM
ZGPhoto's Avatar
He has an 03, he needs to remove everything.
erick846
May 14, 2020 12:55 PM
turbodave
Mar 29, 2019 07:22 AM
FlyingZebra34
Mar 26, 2014 05:14 AM
KlamathMatt
Nov 8, 2013 05:51 PM
lipadj46
Feb 11, 2010 07:45 AM
