Purge Valve Pipe?
Old May 19, 2018 | 03:32 PM
CollieRover's Avatar
Default Purge Valve Pipe?
The pipe that plugs to the purge valve on the throttle body is constantly slipping out. I have searched through rave and cannot find it in there.
Is that supposed to be in there with a sealant or something?
Old May 19, 2018 | 03:58 PM
Saturnine's Avatar
Just a hose clamp on mine
The grey valve, right?
Old May 19, 2018 | 04:08 PM
It's a copper looking pipe that plugs into the Throttle Body pas the Position Sensor.
It's just slipping in and out. The Hose clips on with the same type of connector as the fuel line does.
Old May 19, 2018 | 04:28 PM
OverRover's Avatar
I think you are talking about the smaller of the 2 nipples, the one on the intake (larger is on the TB).
Either way those are pressed in, but if it comes out I use high temp epoxy ( something like quicksteel )
and they will stay in place no worries.
Old May 19, 2018 | 05:43 PM
yes! The one in the first pic. I’ll have to get some high temp epoxy.
Thanks!
Old May 20, 2018 | 10:00 AM
I got it put back in, and for the record it is in the Upper Intake Manifold.
austinlandroverbill
Apr 1, 2015 06:26 PM
discodefender
Feb 15, 2009 02:41 PM
two45triox
Sep 23, 2008 10:23 AM
rsr50
May 6, 2008 10:55 PM
BuckMontecristo
Jul 27, 2006 10:19 AM
