Purple Ice
Old 01-23-2009 | 05:25 PM
jkid's Avatar
Default RE: Purple Ice
ORIGINAL: DiscoRom
Do not use distilled water in an aluminum radiator. I thought we should only use distilled water?
Yeah, I remember reading that on the label too and thinking 'say what'. Wierd. Maybe it means straight distilled water? I don't know. It is very hypotonic andwould have the tendacy to attract minerals, but I wouldn't think itshould matter when mixed with antifreeze/coolant.
Old 01-23-2009 | 05:29 PM
Jupiter Rover's Avatar
ORIGINAL: Disco2Guy
I thought you had to use distilled water because tap water contains minerals that will collect inside the rad and cause blockage. Like how the openings for a shower head get clogged over a period of time.
That Is why I use Distilled in my DII.
Old 01-23-2009 | 05:42 PM
llPANCHOll's Avatar
Ive been looking around on this and it seems to be a running debate..
Perhaps they are referring to not using it with "ONLY" distilled water???
Old 01-23-2009 | 07:20 PM
Back to the original question, Purple Ice or Water Wetter can be used at any time to improve the efficiency of the cooling system and lesson the ware on the water pump.
Both are great products, I use Water Wetter in mine.
Old 01-23-2009 | 07:22 PM
sloppyjoe's Avatar
i have used watter wetter, purp ice, and the hyper cool stuff.
i like the wetter
Old 01-23-2009 | 11:46 PM
I also have water wetter in my disco right now. Though, I have a bottle of purple ice on my shelf in my garage. When summer comes around and it starts getting hot I'm going to drain the coolant and put in 70% water 30% coolant with purple ice.
Old 01-24-2009 | 12:07 AM
redhotbuzz's Avatar
rain water and grain alcohol
Old 01-24-2009 | 06:45 AM
DiscoRom's Avatar
Do I have to drain 16 oz of ethyl glycol out of the system to put in the whole bottle of Purple Ice?
Old 01-24-2009 | 08:49 AM
llPANCHOll's Avatar
If its that full, you did a great job burping the system..
I bet it will fit....
Even if you get half of the bottle in..
Thats more like what is called for isnt it??
stu44mag
05-17-2009 09:56 PM
KBW
04-11-2009 03:52 PM
IDAHODISCO
02-23-2009 02:13 PM
Display
Audio/Visual Electronics
12-12-2007 10:38 AM
rover2003
12-09-2007 10:06 AM
