puttering sound
Old Nov 15, 2005 | 10:03 AM
cottonpatchweims's Avatar
Default puttering sound
My 00 DiscoII makes a puttering sound when I first crank it. It seems to go away after warm-up.
My husband says it sounds like I have an exhaust leak. How can I tell?
Cottonpatchweims
Old Nov 15, 2005 | 08:50 PM
Skelly's Avatar
Default RE: puttering sound
Petrol or Diesel ?
Old Nov 16, 2005 | 03:23 AM
Regular Gas.
cottonpatchweims
Old Nov 16, 2005 | 04:52 AM
Skelly's Avatar
Does it have engine management or old style Distributor ? The dizzy system sometimes means that a cold running engine misfires slightly till warm if the dizzy needs replacing... If it is slight timing issue it could also possibly be the auto choke.
Also, it is possible that the joint between the manifold and the down pipe of the exhaust is not sealed correctly. This would mean a gentle puttering until the exhaust system heats up, when it goes away... and I have also had some small experience of Cats making odd sounds when cold on brand new cars.... can you see if there is any smutting around the exhaust joints or around the manifold ?
GB.
mvjimenez
Jun 12, 2010 10:25 AM
jvanbelkum
Oct 22, 2007 02:20 PM
philipm7
Aug 27, 2005 10:12 PM
lenra
Dec 9, 2004 06:09 AM
matthew.shore
Dec 2, 2004 04:10 PM
