Putting back together
Old Dec 2, 2011 | 07:45 PM
MrFlea1's Avatar
Default Putting back together
I am going to start putting the intake pieces back on the motor. I have a new intake gasket that is rubber coated. Should I use sealant on the entire gasket or just at the water inlet/outlet ports. Seems like the last time this was done someone did the entire gasket. Info greatlt appreciated.
Old Dec 2, 2011 | 08:52 PM
Specifically which gasket are you talking about, the valley pan gasket or the intake gasket between the two manifolds?
Old Dec 2, 2011 | 08:53 PM
boris_gti's Avatar
Valley pan gasket????
You only put RTV gasket on 4 corners around the heads. You will see little notches in 4 corners. Let me know if you need pictures. I got some from a few months ago when I did mine.
Old Dec 3, 2011 | 09:25 AM
MrFlea1's Avatar
valley pan gasket Mike, but Boris answered the question. The intake between the two manifolds uses NO sealant
Old Dec 3, 2011 | 03:41 PM
boris_gti's Avatar
RTV sealant goes in these 4 corners.
Don't forget to put locktite (blue) on air intake bolts because they tend to vibrate loose and then you are going to have major problems (oil leak, coolant leak, rough running, etc...)
Hope this helps.
Old Dec 5, 2011 | 08:17 PM
MrFlea1's Avatar
Today was the day of recconing. Got the Rover back together plus a few extra bolts?? Hooked up the battery turned it over and started right up after the fuel pressure took effect. Sounds smooth/quiet and idled nice and even. Made me feel good. Took my time and did it right.
capthook
Apr 10, 2012 09:20 AM
rlrigsby
Apr 10, 2010 04:58 PM
mcrw
Jan 29, 2009 07:48 PM
adowgiert
Jan 22, 2007 06:02 PM
