Putting a Chevy Engine in my Discovery II
Old Jun 26, 2015 | 11:30 AM
  #51
captain1976's Avatar
Default video of Chevy engine in Rover
Originally Posted by captain1976
Well I decided to get going with the project in which I purchased a Chevy 4.3L V8 which were only made for 2 or 3 years for the mid 90’s Caprice.
I only have 6 months a year since I live in Florida during the Winter. The displacement is close to the original Rover 4.0 and since my engine is junk. My Rover is a 1999 and was only on the road for 3 years before being stored inside. Has less than 100K and still has that new car smell.
I already worked out the electrical and computer controlled stuff like shifting, timing and other functions last fall.
I will use Chevy items such as A/C Compressor, Alternator, Starter, Fuel Injection, etc. I will use the Rovers ignition system and also fabricate its power steering and air pump to the left side of the engine.
Once mounted I want to use those Chrome plated Chevy exhaust manifolds.
Also plan to adapt the Rovers cooling system and will make this a dependable every day driver.
The first step was to remove the old engine and get some measurements. The Chevy engine which I purchased last Fall only has a few thousand miles on it so I cleaned it up real good.
No sense in overhauling a low mile engine so I simply changed a few items and painted it. Also didn’t want to work on the floor or have it swinging around on an engine crane so I made a contraption where I can easily work on the back end at bench height.
The Rover torque converter pilot shaft is a bit smaller than the back of chevy crank so I had a spacer made for installation alignment. Even though the crank, converter and spacer all move together, I don’t want the spacer sliding back on the shaft while running so I secured it with a couple of set screws with thread lock.
With holes drilled into the chevy flywheel and torque converter in place, I need some additional clearance to accommodate the Marks adapter plates I am ordering. To accomplish this you need a shorter torque converter.
Since going out and finding one looks to be a hassle, I’m having the bell housing milled a few thousandths on each end.
Will keep the info and photos coming as I progress. Any question I will be happy to answer but I may have a few myself.
The last photo shows the Chevy engine with the Rover Torque Converter installed
http://www.youtube.com/watch?v=XVMyEjauHjk&sns=em
Sent via the Samsung GALAXY S®4 Active™, an AT&T 4G LTE smartphone
Old Jun 27, 2015 | 08:54 AM
  #52
robL's Avatar
Wow, truly inspirational. It's another of those things that people have said won't work only because nobody tried it. Seems completely logical to me.
Congrats on your progress, can't wait to see it done.
Old May 16, 2016 | 07:18 AM
  #53
dgi 07's Avatar
I know this is 2 years old, but I'm subscribing for progress.
captain1976
Jun 9, 2023 07:46 AM
DiscoBenjamin
May 18, 2011 07:53 PM
Gordon Bombay
Feb 25, 2010 09:46 PM
Willie 00D2
Sights N Sounds
Sep 3, 2008 04:09 PM
Mee
Aug 11, 2005 12:43 PM
