Quad oil coolers too much?
Old Apr 8, 2020 | 04:20 PM
Nosugar0carbs's Avatar
Default Quad oil coolers too much?
I have ran into this idea prior engine and radiator installation. Wondering if anyone has tried or success stories or thought about air flow. Ive got a new Hayden fan blade/clutch and aux fan on when ignition is on as well, any idea if airflow could be an issue. 2 trans coolers and 2 engine oil coolers.
Old Apr 8, 2020 | 04:32 PM
Discorama's Avatar
Engine oil gets hotter than coolant and the air flow is in the direction from the oil cooler onto the coolant radiator. So it's safe to assume that the coolant doesn't get cooled, but probably even heated further up in those areas and the overall cooling effect is impacted negatively. For the transmission cooler I don't know, because I don't know the trans fluid temps.
Old Apr 8, 2020 | 04:42 PM
Alex_M's Avatar
I ran dual trans coolers and no oil cooler. No, you will not see a bearing effect of the coolant, but your effectiveness of cooling will be decreased.
If you tow or off road any I would recommend dual trans coolers and no oil cooler. If it's just a street vehicle I'd leave the stock coolers in place.
Old Apr 8, 2020 | 05:30 PM
This truck is a hauler and lots of idle hours. She’s got an aluminum rad with the inline thermostat mod set with 170* stat, no catalytic converters, Hayden fan/clutch mods do some heat shielding. She has been doing well with miami heat driving and idling, just trying to make her better.
Old Apr 10, 2020 | 08:04 AM
Alex_M's Avatar
In that case I'd definitely dump the oil cooler and pipe it in as a second trans cooler. With the 170* inline thermostat, you don't need the oil cooler even in the Miami heat.
Broken08
Dec 26, 2019 04:05 AM
Big Jim Swade
May 15, 2017 06:15 AM
cobbcj7
Dec 18, 2016 03:43 PM
Danny Lee 97 Disco
Jul 18, 2011 09:01 AM
Spike555
Jun 6, 2010 05:49 PM
