Question about Front Driveshaft Seal/Installation and Rotor/Disc Screw
Old May 31, 2009 | 04:48 PM
lipadj46's Avatar
Default Question about Front Axle Seal/Installation and Rotor/Disc Screw
OK I got everything off to replace my hub but have a couple questions:
1) I had to drill out the screw that holds on the rotor/disc because the phillips head was shot. Can I get a replacement screw from a local shop or do I have to order it?
2) I was also having a gear oil leak from this side so I took out the whole axle so I could replace the seal. Can I get a seal from the local autozone etc. or do I have to special order it?
3) When I replace the axle is there anything special I have to do or just fit it in to the differential and press it in then replace the hub? Does the metal flange the seal against the axle seal just press up against from the outside? Or does it fit in the rubber seal somehow?
Old May 31, 2009 | 05:40 PM
You dont need to repalce that screw, the wheel will hold the rotor on.
Yes AutoZone will have the axle oil seal.
I do not know for sure.
Old May 31, 2009 | 05:44 PM
lipadj46's Avatar
Thanks, It looks like the Axle flange is just is pressed sealed against the rubber gasket. I'm going to just put it back together without the rotor screw then.
0304Disco
Oct 17, 2012 04:11 PM
bballjames
Sep 8, 2012 07:59 PM
A5scott
Jun 17, 2012 05:59 PM
NJ_LR3
Apr 2, 2012 06:10 AM
lipadj46
Aug 17, 2009 10:08 AM
