Questions about 1999 DISCO2
Old May 30, 2012 | 11:31 AM
drowssap's Avatar
order a 8mm 12 point 1/4 inch drive socket, a set of valve cover gaskets and a upper intake gasket and you should be done in an hour or so.
Old Jun 2, 2012 | 02:25 AM
NWROVERS's Avatar
GOOD NEWS, or bad. Depending on the point of view. as of today, FRIDAY. I can say that i officially own a DISCO2. But with all good news comes bad news. On my way home from work today I noticed that my rear wiper doesn't work, Yay. i figure it could be just a fuse. I'll look into that later. but the one thing is that i have Two AMIGOS. The TCS and the Down hill control lights are on. My question is. Would those be caused by the ABS Modulator? I don't have an ABS light on and there is no codes on the ECM. The Brake on the front are a little worn but are only at 85% The fluid looks clean. Would it be advised to do a brake system flush just to be on the safe side? Or should i tackle the ABS Unit and go from there. I will hopefully be ordering up the ABS scanner tomorrow, Saturday, just to have it on hand. You never know right.
Thanks in advance ford any info.
MuddMouth
Sep 30, 2010 10:30 PM
tommytwotone
Sep 22, 2009 05:09 PM
Sid009
May 27, 2009 04:07 PM
felixx23
Jun 2, 2005 12:05 AM
kartoudi
Dec 11, 2004 04:47 AM
