QUICK HELP!! Gas Tank Retaining Ring w/o LR Tool!
Old Oct 20, 2008 | 07:17 PM
jmt's Avatar
jmt
Default QUICK HELP!! Gas Tank Retaining Ring w/o LR Tool!
I cannot get this damn retaining ring on the tank to re-fit the pump. Does anyone know how to get it on without the land rover tool?
Old Oct 20, 2008 | 10:51 PM
tacomatech's Avatar
Default RE: QUICK HELP!! Gas Tank Retaining Ring w/o LR Tool!
Use a hammer and a punch.
Old Oct 21, 2008 | 04:05 PM
redhotbuzz's Avatar
Is it an AEL metal ring part # ESR 3808 g ?
Old Oct 21, 2008 | 09:35 PM
jmt's Avatar
jmt
It's at the shop being done. I couldn't get it.
DO NOT USE A PUNCH. You will crack the ring.
Old Oct 21, 2008 | 09:49 PM
roverwoody's Avatar
Just change my fuel pump. I used a 16.5 inch channel locks. Works Great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 22, 2008 | 06:36 AM
redhotbuzz's Avatar
My oldring was so rusted that I had to use a pair of side cuts to remove it.Then I figured out that the sealing gasket had to be in first to seat the pump.After the ring was alined right... it when right on with afew light taps to tighten it up.
97 D1 AEL tank and ring
Old Oct 22, 2008 | 10:32 PM
tacomatech's Avatar
You won't crack it if you work it gently, easily, and are smart about it. Brain over brawn in a case like this.
Old Oct 22, 2008 | 10:56 PM
jmt's Avatar
jmt
Not on a D2. The nylon retaining ring is not meant to come off.
To replace it, you must grease it and slip it on using some tool from Land Rover.
We boiled it in hot water to make it pliable and screwed it on as far as it would go. It lacked about a quarter turn before being properly seated. We used a punch to attempt to seat it and cracked it. The ring never moved.
The 03 and 04's have a different pump and locking assembly. I'm not sure how they are on any previous to it.
Old Oct 23, 2008 | 01:52 AM
tacomatech's Avatar
I work for a dealership and have done these fuel pumps plenty of times. There is no need to grease it. No tool to slip it on. Use silicone spray to lubricate the pump gasket and make sure it goes in straight and seats fully. There is a tool to tighten/loosen the retaining ring, but not to "slip the ring on". If done correctly, you should be able to tighten most of the way by hand. Boiling it probably made it brittle and caused it to brake. I have actually fully tightened these before by hand when only trying to get the threads started. Sorry to hear about your luck and I hope it works out for you.
Oasisplayer311
Aug 12, 2015 10:43 PM
DustyLBottoms
Mar 5, 2015 01:41 PM
skampdaddy
Oct 20, 2011 08:07 PM
nevada ben
Jul 17, 2011 09:38 AM
CO Disco
Oct 28, 2010 10:38 PM
