Quick Question - lucky 8 spacer and fox shocks install (will delete after)
Old Oct 23, 2019 | 09:28 PM
GoRoll's Avatar
Default Quick Question - lucky 8 spacer and fox shocks install (will delete after)
Does the lucky 8 spacer go under the bottom cup?
and all fox shocks are installed with the piston upside down right?
I’m 99% sure until a friend came over and said that those spacers goes on top and I’m installing the shocks upside down...
Spacer... there is just no way this can go on top, it doesn’t even sit on top of the springs...
Sample photo I found on the Internet but mine will be installed in the D2...
The fox shock should be upside down right?
Old Oct 24, 2019 | 02:43 AM
JUKE179r's Avatar
Piston travel side down. I dunno about the spacer.
Old Oct 24, 2019 | 04:49 AM
SundayFunday's Avatar
Spacer puck is installed under the coil retainer plate - just as you have it in your photo.
(this will be true front/back)
Fox shock installed with body on top, stanchion To axle.
NVDiscovery
Oct 9, 2015 08:15 AM
lighting
Apr 4, 2015 03:06 PM
HI Rover
Oct 19, 2014 11:51 PM
Discolife
Jan 27, 2013 11:16 PM
razorbak
Feb 16, 2006 05:49 PM
