Radiator Leak
Old Aug 9, 2016 | 07:11 PM
Alex_M's Avatar
Mine had the same leak a while back. J did the same as you, RTV on the screw and stuck it back in. I've barely driven it since then, but I haven't noticed any leakage.
Old Aug 10, 2016 | 08:18 AM
Best4x4's Avatar
You can leave it connected. You will have to wiggle it free from the radiator. It has slots and one 10mm securing it to the radiator.
Old Aug 10, 2016 | 12:05 PM
DiscoCam's Avatar
OK that's good. Thanks.
Old Aug 11, 2016 | 08:42 PM
shanechevelle's Avatar
If you use JBweld you don't need a new radiator.
Remove some coolant, spray cracked area with some carb cleaner or other super chemical, starting fluid, brake cleaner, etc...
Mix up some JBweld, pay attention to the JB, if its adhering and sticking to the plastic, youll have a good seal, if it isn't then the plastic isn't clean enough.
Lather that stuff on there, build it up, whatever, and then get our your dremel and shape it.
That stuff bonds fantastic and is stronger than that plastic.
Put the new radiator on the shelf and wait until you really need it.
Old Aug 11, 2016 | 09:33 PM
dr. mordo's Avatar
Yeah, unless it's very old and probly stopped up anyway, I'd try JB or RTV to stop the leak.
Old Aug 12, 2016 | 12:30 AM
DiscoCam's Avatar
Kind of too late for that. I just put in the new one...
But I'm glad I replaced it anyway. There was a lot of junk/sediment in the bottom of the radiator (probably from running dex-cool for 100k). It's also my daily driver so having a new radiator lets me trust the car a bit more.
Old Aug 12, 2016 | 08:01 AM
Best4x4's Avatar
To me $100.00-150.00 Radiator is a small price to pay vs running around with a patched up cooling system that "could" fail at any time.
Old Aug 12, 2016 | 09:44 AM
DiscoCam's Avatar
I totally agree.
Old Aug 13, 2016 | 07:56 PM
jfall's Avatar
Please don't Eff with an old radiator.
Pull it out.
Throw it in recycle.
Get a new Nissens radiator from RockAuto
cheapest way to go.
Old Aug 13, 2016 | 08:13 PM
DiscoCam's Avatar
Pull it out.
cheapest way to go.
Got a Nissens from Lucky8 (had some issues with RockAuto before)
I put it in two days ago and haven't had any issues.
Simonscyclist
Dec 3, 2009 07:21 PM
Chrisinhouston
Jun 12, 2009 09:12 AM
rgrizzard
Mar 6, 2008 10:16 AM
2003Disco2
Jun 15, 2006 01:46 AM
ferrelltodd
Dec 8, 2005 02:46 PM
